new valve cover gasketand still leaks. is there a aftermarket steel valve cover instead of the plastic that doesnt always leak? |
This shows the requirement of making sure ALL gasket mating surfaces are smooth and clean. Takes a bit more time, sure, but it prevents issues such as mentioned here ...
believe me i cleaned the head clean and checked the cover really good. and used a bit of silocone too. warpt head or cover? i herd they always leak, happend on my other twincam all the time and i see it on a lot of them when they come into the shop im at. no aftermarket covers?
hmmm ... Guess I have just been lucky. Five different Saturns, ranging from a 93 SW2 all the way to 2002 L200, with no leakers ... |
Well you did something wrong ... maybe you bought after market.
Use Saturn OEM gasket and don''t over torque
Derf is on the button here over torquing is the culprit a lot of times
yeah maybe i over tightened.... ill get the oem gasket and torque to specs so im on the safe side. thanks guys
| All times are GMT -5. The time now is 04:39 AM. |
