-   -   Transmission Chess Saturn sl2 01/ FLuid Leak (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/transmission-chess-saturn-sl2-01-fluid-leak-3713/)
kobetx4404 Sep 1, 2009 09:33 PM
I am experiencing excessive fluid leakage. The underside of my trans have always been moist, while sitting off there isnt a drip. If i start my car there is a constant drip. This is in the same story in neutral. Shifted into drive causes a drip that is steadier then park or neutral. Reverse is a whole different level. There is a steady stream!!!
Does anyone have a few pointers on how i should go about trouble shooting this? I could just take it to the shop but it may be a simple fix like a broken gasket.
HELP!!!
Thanks
saturnsdn Sep 2, 2009 12:36 AM
any idea where the leak is coming from?
if from the front its possible your filter is leaking somehow (looks like and comes off/goes on just like oil filter)
