not retrieving trouble cods from dlc
Old 05-07-2010, 11:54 AM
miami man's Avatar
Default not retrieving trouble cods from dlc
on my 1999 slt my scanner will not retrieve any trouble codes nor power up my scanner. i have checked all of the fuses on the interior fuse panel and the are all ok.
thank you for any help
Old 05-07-2010, 07:35 PM
I know I'm a foolish fool for asking, but are you COMPLETELY sure you have the right tool for the job?
Old 05-08-2010, 11:48 AM
miami man's Avatar
yep have retieved trouble codes for other people but mine will not retrieve any information
Old 05-08-2010, 06:46 PM
OK - I guess you need to look at the underhood junction block ..... there are a couple of fuses out there that go to the PCM (and also the diagnostic port)
Old 05-12-2010, 10:33 AM
miami man's Avatar
i was told by a good source to look for a loose ground wire near the computer or dlc
Old 05-18-2010, 09:42 AM
miami man's Avatar
the body fuse is ok and i will spray some elecrical connector cleaner on the dlc and see if that works
Old 05-20-2010, 09:39 AM
miami man's Avatar
i changed body fuse and checked the battery pin on the dlc and no power to the pin.
Old 05-20-2010, 11:35 AM
Well .............. have your "good source" fix your car.
Old 05-20-2010, 05:03 PM
miami man's Avatar
ok i will
Old 05-20-2010, 05:07 PM
Thats the ticket
Quick Reply: not retrieving trouble cods from dlc
