sway bar 1997 saturn sl1
the sway bar has disconnected from the front passenger wheel. any idea where i can get a new one, also do i need to replace it or just get new bushings and hardware to attach?
Sounds like you need new end links ... try your nearest SATURN parts counter.
I doubt the front has end links as I've never noticed one on mine. mine goes straight to the lower control arms, the rear however does use end links. how was it disconnected? if broken best to check ebay, junkyards, don't know if the dealer would still carry them.
thank you! got a new one from dealer and installed it! everything works fine now
Glad to hear you are 'working fine' ...
| All times are GMT -5. The time now is 08:48 AM. |
