-   -   Sw-2 1995 - what is this bolt called and what do I torque it to (rear hub assembly) (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/sw-2-1995-what-bolt-called-what-do-i-torque-rear-hub-assembly-13333/)
Gunnar Aug 29, 2024 02:44 PM
https://cimg3.ibsrv.net/gimg/www.sat...6bba1f380d.jpg
Gunnar Aug 29, 2024 02:47 PM
It seems to be 10mm , had noise after replacing hubs so was going to clean things up and put this to proper torque , but not sure where to find this information without knowing the nomenclature for these parts
Also do i need to loosen loosen and tighten them in criss cross order?
Greg97SW2 Aug 29, 2024 11:09 PM
The Haynes manual lists the hub to knuckle bolt torque as 63 ft-lbs. I would tighten them easily in a couple of stages.
