Kikbxr |
11-28-2010 08:00 PM |
Starting problem
Hi, I have a 1997 SL Stick SOHC. The problem is it started fine today and then I went to start it again and got nothing. All lights come on but when you turn the key it does nothing not even a click from the solenoid. I checked all the fuses in the box and under the hood the were labeled ign. All were good. The connections on the cables are tight. Is there a fusable link somewhere that I'm missing or do the starters just crap out without warning? Could it be the nuetral safety switch on the clutch? Any help is appreciated. Thank you.
