SOHC to DOHC swap........
Old Jul 18, 2008 | 06:42 PM
Darcosos's Avatar
i got a 95 sl1SOHC and i was in need of some general help......what is needed to complete this swap? i know the head(and everything inside it), intake manifold,throttle body,and valve cover. is there anything else needed for this? are the computers any differant between the two? any sensors needed swapped for this?? im new into this saturn business....so any help would be greatly appriciated. thnx
i know the timing chain is already needed in this swap. do the pistons or crankshaft need changed?? anything with the fuel system?? Edited by: Darcosos
Old Jul 18, 2008 | 08:44 PM
95jive's Avatar
http://www.differentracing.com/tech_...dohc_swap.html . check that out it will aid you greatly.
Old Dec 6, 2008 | 01:14 AM
qwiksl1's Avatar
you for sure need the pcm and if its an auto a transmission for dohc if you use sohc pistons on dohc head you lower the compression ratio because the sohc pistons are dished in instead of flat if you''re planning on boost or nos go with the lower compression pistons
bluesc1
Feb 21, 2010 09:15 AM
MISSOURI_PAPA
Headers, Intake, & Exhaust
Jan 2, 2009 05:11 PM
KDR65
Dec 28, 2008 01:58 PM
wick250
Jul 5, 2007 11:52 AM
slowride
Apr 13, 2007 04:22 PM
