SL2 venting coolant
Old May 20, 2008 | 12:36 PM
wanderingjoe72's Avatar
A little while ago, I noticed a venting of coolant from the overfill container. This happened when I had driven for a while and then had to idle. I noticed that the temp dial did not get above the quarter mark. so no overheating was indicated. I replaced the thermostat. It appears to be doing it again.
Has anyone else encountered this? I am considering doing a flush of the radiator. There is no leak present on the water pump. Any suggestions? Edited by: sw2cam
Old May 20, 2008 | 05:52 PM
TheEngineer's Avatar
possibly try and bleed the system of air. There may be air pockets that are causing the bubling and overflow. Also make sure that the system is not overfilled. And i beleive there is more than one sensor but dont quote me on that.
Old May 20, 2008 | 05:55 PM
Cool, Thanks for the info. I'll give that a try.
Edited by: sw2cam
Old May 20, 2008 | 06:25 PM
murcielago543's Avatar
i had the same problem on my car
You need to drain the coolant system (make sure to use a DEX-COOL liquid)
And you need to change the filling cap of the coolant container ( the filling
cap cannot support the pressure anymore so the collant is just venting away)
Old May 20, 2008 | 06:35 PM
awesome. I will definitely. try this one.Edited by: sw2cam
Old May 20, 2008 | 09:24 PM
Replace the cap and do not over fill the bottle.
Old May 21, 2008 | 09:12 AM
Low Saturn's Avatar
I agree, replace the cap. Its not air in the system, the system has a deairation line.
Old May 21, 2008 | 10:30 AM
</>I really appreciate the response. I am going to pick up a cap today. </>
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
</>Edited by: wanderingjoe72
Gibbage
Jun 13, 2009 03:46 PM
99Keisha
Dec 14, 2008 02:45 PM
rabobanks
Jul 7, 2008 09:10 AM
photomanb
Jun 15, 2008 01:47 PM
jn_mohit
Mar 22, 2007 02:06 AM
