-   -   SL2 stumbles/hesitates on acceleration (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/sl2-stumbles-hesitates-acceleration-9054/)
kacfiz Nov 29, 2013 08:17 PM
Hi, I just bought a 2001 Saturn SL2 about a month ago. Almost immediately the code P0410 popped up and it turned out to be a bad air pump. I changed that and had no problems for a couple of weeks. Then I came home from work one day and it started to idle rough and the MIL was blinking. The only code it gave me was random cylinder misfire so I researched a little and replaced the ignition module, coils, wires, and plugs. That fixed the problem but now I have a new problem.
The engine idles perfectly now (maybe a little high) but when I accelerate it hesitates for a split second and then lunges forward. I've scanned for codes and it's not giving me anything! I checked the gap on the plugs and made sure they were at .040, they are. It even died trying to take off from a red light once (embarrassing). I don't know where to go from here, help?
keith Nov 30, 2013 09:07 AM
Does the throttle stick? That is when it is at idle, it takes a little extra pressure to get the throttle to start to move, particularly if it has been idling for a minute or two? If so, you need a throttle body cleaning. If you want to do it yourself, let me know and I'll post the instructions.
I dirty throttle body is often caused by an EGR valve that stays open a little too much. The EGR gasses blow right on the backside of the throttle body, gumming it up.
Is the car warming up as it should?
kacfiz Nov 30, 2013 04:33 PM
Thanks for the suggestion. I don't think the throttle is sticking. I mean it feels normal anyway. The car does warm up quickly however the gauge never reaches the middle line. I don't know the proper operating temperature but just judging by the gauge on the dash it seems to run a little colder than normal. I did just replace the ECT sensor but that didn't do anything.
Just for more info, I did check the TPS using a voltmeter and it seems ok. Could the idle air control valve cause this condition? I also suspected a clogged fuel filter but it has good power at high RPM's so I don't know. Oh, and it also seems to only happen after the engine has warmed up.
I don't have a lot of experience with Saturn so I could clean the throttle body if you think it might help.
keith Dec 1, 2013 12:39 PM
Its not the idle air control, that would not cause this problem. Everything points to either a vacuum leak or low fuel pressure or possibly dirty injectors. Injectors don't usually all clog up at once though, and a vacuum leak should result in a high idle, unless it is a very small leak, and a leak that small should not cause this problem.
On my Saturn, the coolant temp gauge stays about two needle widths above the 1/4 mark. Last summer when I was in Death Valley when it was 121°F, the needle climbed to about one needle width above 1/2, but that the highest I've ever seen it go.
A clogged fuel filter will be noticed when you are WOT at near redline. Then the engine will start to miss or just loose power suddenly. So I agree that is probably not it. My next guess would be the MAP sensor.
But before going there, I would want to put an analog voltmeter on the front O2 sensor to check its response time. There is a condition, just before these finally start setting a code where the sensor is operating within its voltage parameters, but is getting slow to respond. It should sweep between its lower and upper limits about once a second, but when they stat to slow down to once every 3 or 4 seconds, then you can have this issue.
If the sweep is normal, then I would look for either a resistance problem in the MAP sensor wiring or a pinhole vacuum leak very close to the MAP sensor, like maybe its seal or remove the MAP sensor and see if its port is partially clogged. If there is a delay in sensing the change in manifold vacuum, again the computer will be delayed in adjusting the A/F ratio and you will get a stumble.
kacfiz Dec 4, 2013 11:28 PM
Thanks for your help, sorry for the late reply. I did check those things to no avail but I finally found the problem. Apparently when I installed the new plug wires I crossed #1 and #4. I just switched them to 4,1,2,3 and it accelerates smoothly now. Go figure
Rubehayseed Dec 5, 2013 06:39 AM
Yep, that would do it. Sometimes you luck out and discover it's something simple. Congratulations.
02saturnsl1 Dec 7, 2013 10:57 AM
I thiught that since 1 and 4 are in the same coil it wouldnt matter with post the wire for 1 or 4 is on dont they fire together at same time?
keith Dec 7, 2013 04:37 PM
There is a capacitive plate under the #4 side of the coil that is your cam position sensor. Switching these wires is like putting your distributor in 180 degrees out, which would not be a problem for a lost spark ignition, but it causes the fuel injectors to pulse out of sequence.
If you had switched #2&3, you would never notice it.
kacfiz Dec 8, 2013 05:31 PM
Thanks yea I'm glad it was something simple. Guess I'll pay better attention next time. I wonder though why the symptom only occurred after the engine warmed up. Could it have something to do with open and closed loop?
keith Dec 9, 2013 12:13 AM
You dump a lot of extra gas in when the engine is cold, it would mask the problem.
