1998 SL2 starting trouble. DOHC MPF This car starts OK when cold. When it is hot it will not start, engine cranks but takes a long time to start. cleand TB and replaced plugs, also have techtron in the gas, any ideas, once it is runing it will run all day. as long as you donot shut it off No error codes
My guess is either your starter has some issues and its getting to hot when the car is running. Could be bad wiring there. Or it also may have to do with a clogged EGR valve
| All times are GMT -5. The time now is 06:52 AM. |
