Sl2 and Sl1 plug wire difference
Old Feb 7, 2010 | 03:50 PM
mbhsl200's Avatar
Default Sl2 and Sl1 plug wire difference
Hi, new to the forum. But not new to cars or Saturns. I have had a 92 Sl1 before and a 99 Sl2. My question is i just picked up a clean Sl2 with 159k. Runs pretty good and esp after the tune up. When i went to advance i think they gave me the sl1 wires. I looked up the part number on the box and it says the sl series with the vin number 7. Im guessing sl2 is 8?? Are there any difference in performance or just fitting?? I installed them before i came across this and the car runs beautifully esp after the tune up. If its a big difference ill go and get the SOHC motor ones. Just not sure.
Old Feb 7, 2010 | 04:12 PM
mbhsl200's Avatar
Maybe the vin number is 7 for the DOHC, i think i got confused. I guess i got the right wires then.
Old Feb 7, 2010 | 05:21 PM
Get the correct plug wires, if you changed them you can see they do not fit properly, and people wonder why I use UPS.
Old Feb 8, 2010 | 06:35 AM
7 vin is DOHC
Old Feb 8, 2010 | 07:25 AM
mbhsl200's Avatar
Thanks Derf. Well i got the right ones then so thats good. I pretty much figured i did after looking at pics of the Sl1 motor. Now i guess i gotta change the valve cover gasket. Alot of oil down around number 1 plug.
Old Feb 9, 2010 | 08:08 AM
change first or you will wreck your pristine shiny new wire set
Old Feb 9, 2010 | 05:45 PM
mbhsl200's Avatar
Valve cover is done today!
mandee_07
Aug 7, 2013 08:32 PM
pyro100
Feb 25, 2009 11:28 AM
jfm567
Jan 2, 2009 05:19 PM
som1dies2nite
Nov 8, 2007 07:52 PM
Zulu747
Headers, Intake, & Exhaust
Jun 6, 2007 02:04 AM
