SL2 clutch pedal noise ???
just bough my SL2 on 7/11/11
only 2 issues #1 = only when starting out in 1st gear, release clutch about half way and it makes an odd sound ..... i describe as a spring dragging against something... ? can slightly feel a dragging feeling in pedal, I've looked down into the clutch cable/linkage area there and don't see what could be making the noise. #2 = with all power options shouldn't it have keyless entry? also where can I get a decent key fob for the cheapest price? I read something about having connections 4 & 8 in the OBDII outlet and those contacts are there , something about using a jumper to program the key fob's ??? |
i too have that clutch rubber dragging feeling on my 95 SC2.
I tried lubing the grommet where it goes through the firewall with some spray lithium grease. Did it last year. Didn't seem to help much then. This year -- no longer a problem. Not sure any of the above fixed it -- just sharing. |
