-   -   SL1 prone to head gasket failure ? (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/sl1-prne-head-gasket-failure-2404/)
twincharged Aug 25, 2008 08:48 PM
hello
i just bought a 97 SL1 sohc with what i thought might be a bad head gasket or craket head, cause there is pressurized oil being pushed in to coolant ports. so i tore it down and took the head off and the head gasket appears ok, the head check ok from what i can see. are the head on sohc prone to cracking?
thank you
Low Saturn Aug 26, 2008 02:25 PM
Yes.
