Did you or someone else recently service the transmission? If
not, you may have a coolant leak. The transmission is cooled by a coil inside the radiator, if the tube leaks, coolant can get into the transmission and it will do serious damage. Check the fluid, if it is cloudy or foamy, get it changed immediatly and get the radiator replaced. |
on a 98 takeing off the battery terminal dopesnt work and there are no fuse take the car back to advamced or to autozone grab the code reader or ask someone to help u sht off the code autozone is the easyest place to have this done just tell em i wana shut my check engine light off
