| uncljohn |
Aug 27, 2011 08:08 AM |
The automatic seat belts were problem prone. The cable would jump the wheels that guide it and tear them up. Mine were repaired early on with a factory recall. Today? If the fuse is blown and that is all it is, you are lucky. Usually the problem is only drivers side. That is the highest used one. If both are bad probably the fuse. If that don't fix it and you can verify volage is actually there to run the motor, in fact the motor probably runs, you can hear clicking noises as it tries to move things. Forget it. No parts, extremely difficult to get to. I have no idea how and personally would not bother trying to find out.
I always like the idea. I have owned two cars that worked that way. The Saturn as I say was fixed by the dealer and still works now. The mitsubishi when it quit, it stayed that way. The are a maintainence headache.
