Dude,
The stock Saturn wires are like a puzzle, because some are long enough to fit some cylinders but not others so you have to go through alot of the different combinations until you get it right. And then you have to have them lined up in the right order or the routing clip won't stay closed and it looks messy. I don't like messy. And zip ties look awful under the hood. Especially for battery tiedowns. And you can NEVER find large enough zip ties in the color that accents your battery! THEN you have to figure out which coil post is for which wire. AGAIN some reach all of them, some do not and you have to keep messing with it until you think it's right. Then check the firing order online because you don't realize it's on the sticker you're leaning over because you don't keep under the hood clean, and the sticker is covered with.....carbon!! |
