| mfunk49 |
Feb 1, 2007 12:44 AM |
i have a 95 sl2 with roughly 120,000. the belt is making a lot of noise when you first take off. very little at idle but a little. and usually only when you first start it. the belt seemed loose so i decided to buy a new one and make sure this one was tight. i had a very hard time removing when i did this. i found the tension pulley and loosened the nut. i understand this is spring loaded but have never messed with one before. after loosening nut i thought the belt would come off easier. it didnt. i had to pry off with tools. after installing new one the belt noise lessened but is still there. the belt is still a bit loose. my main question is what is the process of tightning a belt with a spring loaded pulley? if i loosen the nut will the spring automatically tighten then i can tighten nut back up? or do i loosen nut, pull up (tension) with socket wrench, then tighten back up? ive heard "self adjusting" and it sound like it tightens up by itself? could someone enlighten me? thank you. (ive been told by a guy at kragen auto that i may need to replace the tensioner altogether..may be the bearing making noise)
