-   -   ramdom oil leak + lifter question (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/ramdom-oil-leak-lifter-questin-3000/)
83cressy Feb 28, 2009 07:25 PM
Hello. I recently did a head gasket on my 95 sl base model. The car was leaking at the valve seals enough to cause the plugs to foul every couple months. About a month after the head was done, I noticed the car would leak oil randomly. sometimes it will be fine for a month, then the next week it will need two quarts. Any suggestions? I am thinking something pressure related? Also does anyone know what way the lifters are supposed to go in the head. My friend knocked them over and I couldn''t tell which way the oil hole used to point. Seems to run fine now but there is a slight tap. Thanks all.
OceanArcher Feb 28, 2009 09:21 PM
On the early SOHC engines, rotate the lifters until the flat sides are parallelto the intake and exhaust manifold flanges and install the lifter guide plates ....
