Quick pad replacement ...UNTIL
Replaced front pads on 1999 SL1. Quick job until I was compressing the caliper piston on the drivers side and the seal appeared to tear (small drip of fluid and I can certainly feel something wrong when I tested the brakes)
Do I just replace the entire caliper or can I replace the seal? Anything special I should know or look for during this job? |
you can rebuild the caliper but it is a delicate process and if you gouge the piston bore of the caliper, it'll be hosed anyway.
Might as well replace the entire caliper and be done with it |
| All times are GMT -5. The time now is 10:06 AM. |
