Quick pad replacement ...UNTIL
Old Jan 17, 2010 | 08:09 AM
ForgottenOne's Avatar
Default Quick pad replacement ...UNTIL
Replaced front pads on 1999 SL1. Quick job until I was compressing the caliper piston on the drivers side and the seal appeared to tear (small drip of fluid and I can certainly feel something wrong when I tested the brakes)
Do I just replace the entire caliper or can I replace the seal?
Anything special I should know or look for during this job?
Old Jan 17, 2010 | 07:11 PM
you can rebuild the caliper but it is a delicate process and if you gouge the piston bore of the caliper, it'll be hosed anyway.
Might as well replace the entire caliper and be done with it
jamnar
Jul 5, 2015 11:48 AM
DCARNEY51
Jun 18, 2015 02:43 PM
crpowell
Nov 17, 2008 11:34 AM
walt1973
Mar 11, 2008 07:50 PM
RaggedGlory
Oct 26, 2007 09:56 AM
