problem with 96 sl1
you have 3 fuse boxed in your car on is under the hood the other is under the driver dash buy where ur left foot would rest and the other should be on the passenger side up agenst the center consual where ur radio and heat controls are. but im telling you if the fuse is blow it will blow again you must find the problem in the wiring. grab a wire diagram from all data or go to the local saturn dealer and ask for a "dashboard lighting diagram" but most likely what it is is that you need to take off the dash and replace the bulbs. i have all kindas of parts for you car if you want i have leather seats all around and fenders motor name it i have it if you want it hit me up at www.stanglov02@msn.com
