-   -   Power Window question (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/power-window-questin-1614/)
LarryS Jan 13, 2008 12:43 AM
I've got a '97 SC2 coupe (I wasn't sure if I should post this here or not seeing how I don't have a 3-door).
Anyway, the power windows work - most of the time.
However, sometimes they'll go down but won't go back up again. I find if I shut the ignition off and then back on, they're okay. Except I'd really like them to work all the time.
I figure I'll lubricate the tracks, but is there anything else I should check?
Thanks,
Larry
'97 SC2
Low Saturn Jan 13, 2008 11:31 AM
Start by removing the outter door panel and lubricating the tracks and gear. You also might need to remove the switch pod, open it up and clean the electrical contacts. If those two things dont work, replacement of the window regulator/motor assembly might be necessary.
