Pcm
If I had to change the PCM , Does it need to be flashed by GM ?
Depends.
If you buy it new, yes. If you get it from a car at the junk yard, as long as it is the same year, and make sure it matches your tranny (auto/manual) you shouldn't have to. |
Thanks for the info .
for the record, the PCMs on the S series are VERY VERY VERY VERY rarely the problem; for the volume of cars out there, the failure rate is miniscule.
Hey bud, I was wrong. After further info, s cars before 2000 don't have a bcm, so they are car specific.
Derf knows his stuff, probably better off listening to him. |
Ok , New to Saturns and just trying to get info on them.
Thank You Ben |
Let's hope I won't need one , It's running again . Thanks
