-   -   p0507? (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/p0507-239/)
pitar Dec 2, 2005 08:58 PM
hey people! I recently bought 2002 saturn sl1, 102k miles, 5 speed manual trans. I am having problems with rpm's because they never go lower than 1200. Check engine light is on, code p0507->Idle Air Control System RPM Higher Than Expected. I tried cleaning the throttle body but it only made it worse because now rpm's are not going lower than 1500. I Anyone experienced something similar? Any help would be appreciated!
Skid2 Dec 6, 2005 01:45 AM
You should check for a vacuum leak first, then remove and clean the idle air control valve and the seat where it screws in.
Generally a high idle is an indication of a severe vacuum leak around
the intake manifold, throttle body, or egr system. When you took it
apart you may have disturbed the part that was leaking and made it
worse. Also check the brake booster and PCV system for leaks. If you
can't find any vacuum leaks then remove the IAC and clean the seat and
valve.
pitar Dec 6, 2005 11:55 AM
Hi and thanks for reply!
I already replaced IAC with the new one from dealer, it didnt help. I couldnt find any vacuum leaks anywhere, aroundegr or throttle body. I forgot to mention that I am also getting code p0301- misfire on cylinder #1. I replaced spark plugs, wires and both ignition modules (all these parts were due anyway) but this code is still on along with the p0507 from before. I think I will just have to bring it to a dealer, I am out of ideas[img]smileys/smiley6.gif[/img]
snnave Dec 10, 2005 10:50 AM
Any luck with your problem? I too have an 02SL1 with the exact codes, PO301 and PO507. I have heard that this vehicle has a problem with a leaky intake manifold gasket. Any help would be great. Does this problem usually cause your gas mileage to decrease?
pitar Dec 10, 2005 12:52 PM
Yes, you are right. After I ran out of ideas I took it to a local delaer and they diagnosed it with bad intake manifold gasket. They estimated parts and labor to be around $590 but I just paid them for diagnostics and took the car to my mechanic who did everything for $200. Intake manifold gasket (from dealer) costs only $12, labor is about 3 hours and there you go. It runs great now, no more codes, no high rpm's. Good luck!
Skid2 Dec 10, 2005 01:05 PM
Not to say I told you so but......the most common problem that causes
the symptoms you described is VACUUM LEAK. Usually leaks around the
intake manifold or EGR system are a little hard to find. Sometimes you
can have an internal vacuum leak in a V configuration engine that
causes the same problem.
Normally you can repair this problem yourself for the cost of a gasket
set as long as you have a little mechanical ability and some patience.
I've done a lot of them on different cars. I have never done a Saturn
but judging from how easy other things are on these cars it can't be
that hard.
Don
snnave Dec 10, 2005 05:28 PM
Thanks guys,
I sprayed a little carb and choke cleaner right at the #1 intake and it surged and all most stalled the engine.
snnave Dec 10, 2005 05:30 PM
Does anybody know the torque value and pattern for the intake manifold on the SL1 1.9L? Should an RTV be added to the gasket to prevent any future leaks?
Skid2 Dec 10, 2005 11:50 PM
TBI models = 188 in/lbs, MPFI models through 99 = 22 ft/lbs according
to my manual. They don't give a torquing sequence. Usually the gasket
manufacturer will recommend RTV if needed. I usually use gasket-tack on
paper gaskets and nothing on cork or rubber.
myjawjeep Dec 11, 2005 07:36 PM
I just purchased a 2002 SL-1, 36000 Miles. Soon after I got this car the SES lighe came on. At first it would come on ,then go off now it stays on. I took it to a dealer, they stated that it indicated thatb Fuel to Rich. They had it 2 days and I was told that they had discussed this problem With the Factory, They tried several different solutions, however nothing so far corrected the problem. Light still on!
The car is running great, and my milage is 40 mpg on the highway.
Would appreciate any suggestion.
