-   -   oil mixing with antifreeze? (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/oil-mixing-antifreeze-5162/)
skorger Nov 3, 2010 09:07 PM
i have a 1994 saturn SL1 and it i keep finding oil mixed in with the antifreeze yet no leaks and no loss of oil from the engine, and cuases serious bogs while driving, suggestions please.
derf Nov 3, 2010 09:23 PM
blown head gasket or cracked/porous head. if oil is in with the antifreeze, there is likely antifreeze in with oil -- it will be milkshakey. Level will seem fine but things are definitely not well
skorger Nov 3, 2010 09:24 PM
possible cost of fix?
derf Nov 3, 2010 09:29 PM
maybe $700 for a head gasket
head from junkyard engine -- not sure -- check the net
if head gasket ---compression test will localize problem to one or more cylinders
if crack in head or head is porous, may be more difficult to locate
OceanArcher Nov 3, 2010 09:32 PM
Hmmmmm --
If it's a head gasket, probably about $325usd. If the head is cracked, probably about $525usd. You can save a portion of that if you do the work yourself, but I don't know your level of expertise ....
derf Nov 3, 2010 09:37 PM
thanks for the financial corrective action, OA
OceanArcher Nov 3, 2010 09:39 PM
Hey - no problem .... we do things more inexpensively here in the South
