i have a 97 sl2 there is oil in the spark plug wells i dont know whats wrong i changed the valve cover and it still leaks what is wrong Edited by: dtone90
Probably overtightened the cover.... adhere to torque specs.Edited by: derf
but it was leaking before to and it was the stock cover
Replace the gasket with a new preformed gasket and only use RTV in two small dabs where the timing chain cover meets the head. Then torque the bolts in the proper sequence to the correct torque.
So the original gasket failed after12 years I''d say you got your money''s worth out of the original.
Did you ensure that both the head and the cover surfaces were clean and free of previous gasket material? |
yea i did im going to look at it tomorrow maybe i did miss something
Just remember that having the bolts too tight is just as bad as too loose.
If it''s just oil in the spark plug wells I''m betting you just didn''t use enough RTV in the circular valve cover grooves that surround the wells when installed. I wouldn''t skimp on the RTV at these locations. When you pull the cover it will be easy to see where the oil leaked from.
Signed, BeenThereDoneThat |
| All times are GMT -5. The time now is 08:06 AM. |
