No coolant flow through system
1996 sw2 dohc wagon. New waterpump, coolant temp sensor, radiator, and thermostat but there seems to be no movement still. Is there any way to bleed the system other than the resevoir tank cap? could the new thermostat block any flow? please help.
Did you flush the rest of the system before refilling with coolant?
i did not... could it be air locked? i am not familiar with saturns and especially the way this system is routed. where would the best spot be to splice in a flusher kit and what should my steps be?
