| Slinkypinkysl1 |
Jul 10, 2013 02:43 AM |
Newbie needs some fuel pump help
Hey everyone I have 2001 sl1 with a 1.9 sohc EFI, she cranks but won't start. Got spark and cps is good and I hear the pump prime when I turn key, however I have zero pressure at the Schrader valve, replaced fuel filter and fuel pump, no luck. Checked all fuses from under hood block as well as instrument panel block and relays too. Everything checks out good until I get to the trunk connector. When I turn the key to "ON" the voltage is only 7.6 volts instead of 12... Any ideas would be greatly appreciated!! Thanks in advance!
