New to me '96 SL: need some help
Old Jul 2, 2012 | 10:08 PM
chevy454's Avatar
Got it aligned...it was so far off it wouldn't register on the machine, so the guy had to eyeball it to get it in the ballpark then go from there. My guy said everything was tight and looked good, though! Drives much better...
Old Jul 3, 2012 | 06:37 AM
Glad to hear you got it straightened out. It's amazing what a good front end mechanic can do, isn't it?
Old Jul 6, 2012 | 07:35 PM
chevy454's Avatar
I bought a new upper engine mount from the recommended supplier on this site but when I went to put the mount on the studs are too short. The studs that were on the engine side look like regular exhaust manifold studs, is that right? Can I get something at the local posts store that will work? Also, the mount didn't sit all the way down on the engine pad, theres probably a good 1"our so gap...but the old one was in pieces so I don't have anything to compare it to?
Old Jul 7, 2012 | 12:04 AM
did you support the engine from below?
Where did you get the mount and studs
I always go dealer on these
Old Jul 7, 2012 | 06:22 PM
chevy454's Avatar
Ya, mount was from gm...i just want holding my mouth right...it's on and fits good.
But, now ive got a loud rattle in drive with a/c on...won't do it in drive with a/c off or in park with a/c ...only when the idle drops way down. It sounds up high, around valve cover...
Old Jul 7, 2012 | 11:09 PM
I noticed when i replace my top mount it required abit of forceful finess to get it in place.
Maybe something wrong with the a/c clutch or a loose bracket somewhere? or maybe the new mount is transferring alittle more vibration than the shot one was - and your hearing something you didnt hear before?
Old Jul 8, 2012 | 12:17 AM
chevy454's Avatar
I should have started it was doing it before I replaced the mount, but I had hoped a new mount would fix it...i did notice the dog bone had done slop in it.
Dylan
Feb 23, 2011 08:54 PM
spoolmy1.8
Jul 1, 2007 12:33 PM
peytonsullivan
Tires
Mar 18, 2007 12:14 AM
spaz
Mar 13, 2006 05:21 PM
DrewsSc
Dec 6, 2005 03:13 AM
