New IAC valve didn't fix idling problem
Old Mar 1, 2011 | 10:38 PM
Trouble Remedy List of things to look at.
It may or may not have any bearing on problems and may be something already checked.
Check throttle linkage or TD sensor not sticking.
Vacuum leaks
EGR system
Transaxle Range switch adjustment TR Sw.
Charging System less than 9 volts or greater than 17 volts.
Correct prom and/or PCM for vehical
MAP or MAF sensor
02 sensor
Engine coolant Sensor.
Each of these items were under a catagory that indicated incorrect idle.
JDC
Mar 16, 2014 04:41 AM
john doe
Apr 9, 2012 01:56 AM
kingbrian
Aug 21, 2010 10:54 PM
Chaos
Nov 12, 2009 08:45 AM
Nekroman
Jul 8, 2008 06:26 PM
