Hey there. I''''m new here. I recently bought a 95 SL1 and I absolutely love it! I paid 900 bucks for it. It has new tires, struts, and brakes. I bought it from a co-worker and he was the original owner. The only thing that has not been replaced is the clutch. I have a repair book and I see that you must remove the engine to replace the clutch. I do my own maintenance on all my cars (my name, 48builder refers to a 48 Chevy street Rod I am building). I''''m looking for any guidance I can find on doing the clutch. I may end up paying to have it done, but I figure I can save $500 or more if I do it. I have a tools, a heated garage and a cherry picker, so no problems there. The clutch seems to be OK so far, but I''''m sure it won''''t last forever. Thanks! Walt Edited by: 48builder |
Why do you think the clutch need replacing? How many miles are on the car? I''ve seen them last over 300,000 miles.
I don''t, yet. It has the original clutch and I don''t know how long they normally last. Good to know that they can last that long. I don''t want to replace it unless it needs it, but I also travel a lot and don''t want to get stuck somewhere. What symptoms would indicate that the clutch is on it''s way out? Thanks, Walt |
Slipping and just not grabbing like it should. And more often than not, the clutch hydrolics go out before the clutch hardware.
There are several indications that a clutch has failed, or is in the process of going bad: 1) Pedal travels to the floor - no pressure or very little resistance; 2)Unable to select/shift gears;3) Clutch slips (engine speed increases with no increase in car speed); 4) Grabbing (chattering) when clutch is engaged; 5) Transaxle rattling or clicking; 6) Unusual noise in or around the clutch housing; 7) Clutch pedal stays on the floor; 8) Clutch pedal very hard to depress. Edited by: OceanArcher |
But keep in mind #1,2, and 7 can indicate bad hydrolics too.
| All times are GMT -5. The time now is 10:22 AM. |
