-   -   Need Help Guys (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/need-help-guys-2277/)
rameans23 Jul 11, 2008 08:15 PM
ok i have a 98 sl and i was drivin today and all of a sudden i lost all electrical power, no battery dummy light or anything, the radio went, running lights and all the gauges but the car was still running. I have also noticed that when i put the key in the ignition and turn it over to acc or to the run postion the needles on the tach and the speedo will just flutter at the 0 mark.
I personally think it has something to do with the grounds on the car but i dont know honestly so if anyone can help i would greatly appreciate it
95jive Jul 11, 2008 10:27 PM
it does sound like it could be a ground.....or a loose arcing wire.
derf Jul 12, 2008 05:02 AM
Sounds like low charge on battery.
Is battery near the end of its expected life span?
Check wiring at battery terminals for corrosion and tightness.
Derf
rameans23 Jul 12, 2008 06:31 AM
the battery i think is ok i think its only been in the car for about a year. does anyone know where i can get a diagram of where all the grounds are
butta96sl1 Jul 26, 2008 07:11 AM
Ok as a former saturn employee and also now a sl owner, i know exactly what is wrong. You need to replace your ignition switch. This happend to me not to long ago, and i''ve seen it a thousand times. If you take it to a saturn dealer there is a recall or bulletinon it. To solve it without a dealer, turn the car off and back on.
butta96sl1 Jul 26, 2008 07:21 AM
If you still want a diagram of the wiring harness for the grounds, I can get you one, but that''s not your problem.
TheEngineer Jul 29, 2008 08:37 PM
try jumping the car...it may be that the alternator is gone and your car is only running on the battery (being why it just died and want start up. Just a guess
Low Saturn Aug 1, 2008 10:51 AM
It sounds like the classic dead alternator symptoms. If you have more than 50,000 miles on the car, chances are very very good that its the alternator.
rameans23 Aug 1, 2008 11:37 AM
thanks guys i will look into it
