need help
I am working on a friends 1995 saturn s series. will start but dies, change the fuel pressure regulator and fuel filter ( filter poured out black fuel) . Poured gas down two cylinders ran like it was choked. check the codes but showed no codes. When the engine dies I hear the pump. what should i check next
from my overall s series haynes manual
key on/engine off: 46-94 psi
car running at idle:
26-31 psi SOHC
31-36 psi DOHC
You said S series but not which one. SOHC or DOHC?
So your fuel pump appears in spec, barely. I'd exhaust all my other options before tackling that one.
How did it stop running?
Also pls go to the user control panel and put your car info in the signature. Thx
26-31 psi SOHC
31-36 psi DOHC
Do you know how to run the computer codes on this car? That's what you need to do first. Shotgunning parts at it and hoping you get it fixed is a waste of time and money. Look under the dash near the steering wheel and you should see the computer diagnostic link. Take a paper clip and bend it into a tight U. Take the paper clip and insert it into the last two holes on the upper row of the link. Now, turn the key on to the start position, but don't crank the car. Watch your check engine light and count the number of flashes you get. Each code that is stored will flash three times then move on to the next code. For example, a code 23 will be two flashes, a pause, then three flashes. It will do that 3 times in a row and move to the next code. The next could be a 32 for example and it will flash three times, pause, then flash twice. It will do this 3 times and then proceed to the next. I hope you understand what I'm trying to explain. You may not catch every code the first time. Don't worry about that. You can run the codes as many times as needed in order to catch them all. When it's done, you'll get a code 12. One flash, pause, two flashes. This will also be done 3 times. If you don't turn the key off after 12, then it will go through them again.
