< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> i have a '96 sl2 and it has been running fine. but out of the blue, it started chugging after i shift gears (manual transmission). once it gets to a certain rpm (maybe 3000) it'll run fine but after the gear change it's real sluggish and "putts". maybe i have water in the fuel? any ideas? |
Do your spark plugs look okay? How about your fuel and air filter. I've also heard that temp sensors can be a problem. |
