Well i'm replacing the map sensor next, then the ECTS, but i've already got a map sensor in hand....
also sorry about the lag in response time, i was at summer camp supervising 16 little tornados for the past week.... |
Well i replaced the MAP sensor, it was grimy and oily, however the check engine light still came on so i'm gonna replace the ECTS next, i figure if this doesnt solve it, it's the onboard computer and its gonna cost me about 120 bucks to fix it
any recommendations on brand of coolant sensor, since some apparently are born to lose and destined to fail |
orielly has the brass tip style cost ya about 11 buck thats if there is one around you cant think of the brand ...get to a dealer get the leads for it too
go oem
+1 on the connector -- dealer only |
Back to the car again...
Sorry took a few days off to get work in order. I managed to find the air intake sensor and replace it, the code is still up for running lean, Next is to find the OEM ECTS and replace that. Ok, I replaced the ECTS, the engine temp gauge is more active now, but it still popped the code, any suggestions from there...So far i have checked Fuel pressure and vac leaks and replaced MAP sensor, ECTS, and AIS..... |
