Location of MAP sensor on 2000 SW2?
My "service engine soon" light is on and the parts store scanned it and said it was a MAP sensor code. I have the Haynes DIY manual but it doesn't give any information on where this sensor is located and how to R/R it. Any help?
I assume it is in the same place as on the older DOHC models -- at the top of the far end of the throttle body.
Make sure you don't lose the little plastic sleeve that is around the sensor port when you pull it -- you'll need to reuse it,
Turns out it is in a different place - it is under the Throttle Position sensor on the intake manifold just beneath the throttle body (left side of car). I replaced it (it snaps out and in) and disconnected the battery for a few minutes. The light didn't go out, so this morning when I got the oil changed, I had them read the codes again and reset them with their scanner. So far the light hasn't come on again, I'll keep my fingers crossed.
E04677
Jan 14, 2010 08:07 AM
thatsreality
Apr 9, 2007 03:43 AM
