key stuck on ACC 93 sl2
title states it all, key stuck in ignition of saturn sl2 on ACC
tried all i can think of, cars in park, steering wheel isnt locked. tried tapping key with hammer, spraying PB bomb in ignition. looks like the ignition is pressed in, not turning in either direction. wanted to try to get some input before trying to source a new ignition |
if its stuck it's stuck.
luckily it needs to be in acc to remove the cyl to replace it -- search the forum -- I think OceanArcher may have a post regarding how to remove the cyl if not it is certainly out on the net |
and get a new key cut at the same time. Thats a new key CUT for the ignition from the dealer. Don't have KennysKey&KelpKorner make a copy of your old worn out key.
Yepper time to replace the cly and key .....
| All times are GMT -5. The time now is 08:36 AM. |
