-   -   idil code 49 or idle code 49 (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/idil-code-49-idle-code-49-a-5493/)
james clark Feb 23, 2011 04:48 PM
1994 sl runs fine but just once in a blue moon when you come up to stop the car well idil up to ab 1100+ and come down then check engine light well come on.code 49 but have check for vacuum leak and only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?and if that was bad should it do it all the time?:mad:(light goes out after you turn car off and start back up)
1.have put new temp sensor in and connecter
2.new muffler
?could converter be clogged up b/c some times i smell a egg smell
OceanArcher Feb 23, 2011 05:44 PM
Code 49 does suggest a vacuum leak. May be a crack in the plastic housing
james clark Feb 23, 2011 06:29 PM
why would it only do it some times? whats the name of the housing?
how do i check converter?should i check it i only smell that egg sometimes.
sw2cam Feb 23, 2011 08:13 PM
Why would you post this in the new member area? Moved for a reason, next time deleted.
derf Feb 23, 2011 09:24 PM
<<only place it seems to idil up at is a black housing on back of carb with 3 lines going to it.what is that?>>
your car has no carb so I have no idea what you're talking about
Post a picture
