wnot stay running
Old 10-01-2013, 07:55 PM
gregreitz1123's Avatar
Default wnot stay running
I changed the transmission on my sl2 put everything back the way it came off and now the engine will start but it idles rough for a couple seconds than goes to normal idle for a couple seconds and than dies, if you push the throttle it dies immediately?
Old 10-01-2013, 08:57 PM
Stop in the new member area and give yourself a proper introduction. While your at it go to the USER CP, open signature and add your first name, location, and car info.
Old 10-01-2013, 10:05 PM
Paul b's Avatar
That sounds like mabe a vacuum leak. Do you hear a hissing sound from under the hood when it is running
Old 10-02-2013, 08:50 AM
Make sure you didn't pinch a vacuum line or wire between the bell housing and block when you put it back together.
DailyPlanet
10-07-2014 12:16 AM
DracoLoco
05-21-2014 06:42 PM
mattl36567
12
10-15-2013 06:06 PM
SaturnJeff
01-15-2010 07:10 PM
rapidion
09-17-2006 10:34 AM
Quick Reply: wnot stay running
