How do i replace the timing chain gasket on a 98SL1
I just replaced the valve cover gasket and realized that the gasket on the timing chain cover needs to be redone aswell. How would I do that? Is there a good article out there about it?
Thanks Alex ________ VOYEUR SPY |
. It is silicone except for the crankshaft seal. You just have to take the cover off,clean both surfaces, and apply a bead of silicone on the cover. Are you sure it is leaking, because that's usually a fairly reliable seal. The crankshaft/vibration damper seal, however, does occasionally fail. It can be replaced without removing the timing chain cover.
| All times are GMT -5. The time now is 08:31 AM. |
