High pressure on AC low pressure line
2000 SL2; getting no cold air from AC, but interior blower OK. Thought the compresser was OK so got a can to recharge. Upon hooking up to the low side (per instructions, with AC on full) the pressure indicates at 100 psi. Would a bad compressor give this indication?
TIA |
So are you in
Lower, Central/Middle, or Upper Franconia and how did a Saturn end up in that area? |
Either a bad compressor, or a massively overcharged system. Any idea at all as to the high side pressure?
Originally Posted by sw2cam
(Post 14175)
So are you in
Lower, Central/Middle, or Upper Franconia and how did a Saturn end up in that area? http://en.wikipedia.org/wiki/Franconia But in the good ol' USA - near Alexandria VA http://en.wikipedia.org/wiki/Franconia,_Virginia Plenty of Saturns here! |
(Post 14176)
| All times are GMT -5. The time now is 09:59 AM. |
