-   -   Hard shifting into 2nd and 4th TAAT (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/hard-shifting-into-2nd-4th-taat-11454/)
Chesterboy1988 Sep 4, 2018 08:03 AM
FYI. If you have hard shifting into 2nd and 4th without reverse slam try replacing your Throttle Position Sensor 1st. My 1997 SL1 was doing it and I went ahead and put a new valve body thinking it was going bad. I had no codes in computer and was baffled on what might be wrong. Then I read about how a bad TPS can cause transmission to shift hard. Replaced it with a new ACDELCO and it now shifts smooth as silk!
Rubehayseed Sep 4, 2018 08:39 AM
That's good information, Chesterboy. Thanks. And welcome to the forum.
