why does my engine smell like gas when i start it
Check your fuel lines and make sure you do not have a loose fitting or damaged line. Fuel spraying around in an engine compartment is a definite hazard ...
Because you still haven''''t changed your ECTS like we''''ve advised, so your car is running richer than hell (with a fuel mix equivalent to that used when it''''s about -40 outside), since you said you disconnected the known\bad ECTS sensor...
If you''''re gonna ask for advice and then not follow it, please stop asking questionsEdited by: derf |
| All times are GMT -5. The time now is 08:35 AM. |
