< src="http://www.google-analytics.com/urchin.js" =text/> </> How do i replace the fuel pump in a 2001 saturn s series < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
Lift the car, remove the tank, remove the pump assembly. Reinstall in reverse order.
< src="http://www.google-analytics.com/urchin.js" =text/> </> thanks. also would that prevent the car from starting or how can i make sure its the problem < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
Its possible. Do you hear the pump prime when you first start the car? Is there fuel coming from the test port?
< src="http://www.google-analytics.com/urchin.js" =text/> </> where would the test port be located? and i dont think i do hear it prime should i be listening from the rear or under the hood for that < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
The test port would be just before the fuel rail. You should be able to hear the pump prime from inside the car. As soon as you turn the key to the run position (without starting the car), you should hear hum for a few seconds.
| All times are GMT -5. The time now is 05:24 AM. |
