-   -   Front Cover Seal - SL1 (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/front-cover-seal-sl1-13509/)
hydromech Dec 10, 2024 12:09 PM
Thank you very much. This is exactly what I needed.
hydromech Dec 10, 2024 12:11 PM
Originally Posted by Greg97SW2 (Post 76250)
The seal bore is on the outside of the cover so it is not necessary to remove the cover to replace. The crank pulley bolt is on tight so an impact wrench is a plus. Pay attention to how the big washer faces and use sealer on the face of it.
Greg, Do I have to use RTV under that big washer (crank pulley bolt). I never used no sealant there... Can oil actually leak through that pulley bolt ?
hydromech Dec 10, 2024 12:19 PM
With cover in place, what is the best way to INSTALL a new seal without special tools ?
What can I use to insert that seal straight and perpendicular without folding it ?
Any advise is very welcome.
Greg97SW2 Dec 10, 2024 11:08 PM
I used RTV on the washer since there was sealer on there from the factory. Also a Saturn tech on the old SaturnFans site stated it was necessary. The seals don't take a lot of force to install and I seem to remember a piece of 1 1/2" PVC made a good drift.
