Engine revs/ high idle
Old Jul 30, 2008 | 08:47 PM
wanderingjoe72's Avatar
A couple of weeks ago my car started high idling to about 3000. It would also spike between shifts (on an automatic). I replaced the idle air control valve, cleaned out the throttle body and had recently replaced the spark plugs. There are no vacuum leaks and I got it back to roughly normal rpms. about 1000 to 1100 at idle and 1600 between shifts or when going from drive to park. Now I am seeing a correlation between the high rpms and running the a/c. The first time it started spiking, I had been running the a/con high for a good amount of time. Recently it started spiking and I found out the a/c had been run. Has anyone else seen this or had this happen? I disconnected the battery and that brings it back down, is there a sensor in the a/c that is telling the system to run high?Any insight is appreciated. Edited by: wanderingjoe72
Old Aug 1, 2008 | 10:23 AM
Low Saturn's Avatar
Check for a vacuum leak at the CCP solenoid at the back of the engine.
It would also help to mention the year and model of your S-Series.
Old Aug 1, 2008 | 07:49 PM
Thanks. I will check for the CCP solenoid.
As for the other part, this in on a 1999 SL2. Thanks.
Old Dec 6, 2008 | 01:02 AM
qwiksl1's Avatar
it could be the throttle position sensor its on the back of the throttle body my car would idle at 2000 rpm wen in nuetral (manual) i replaced the sensor it took care of the problem
Old Dec 14, 2008 | 01:14 AM
Alaska_Saturn's Avatar
Concur on the Throttle Position Sensor (TPS). I had the same symptoms as you, minus the A/C situation. Try replacing the TPS (I think less than $20 bucks) and see f that fixes the problem.
Old Dec 14, 2008 | 07:21 AM
To WanderingJoe72 ...
To answer your question - Yes, there is a signal that goes through the computer box that will boost the idle RPM when you are running the A/C, but I do not think that is your problem. While the possibility of a vacuum leak cannot be ignored, I kinda suspect that Qwiksl1 and Alaska-Saturn have the problem pinpointed ...
Sage927
Nov 7, 2010 05:03 PM
2000inSL2
Oct 28, 2010 12:32 PM
quickplasticsc2
Oct 2, 2009 07:45 PM
rwcjj
Jun 29, 2009 09:56 PM
nick27
Sep 27, 2007 08:37 AM
