i have an odd noise coming from my engine..i believe its the belt and crankshaft pulley. when the car is on, the crankshaft pulley wobbles just a little (.5-1mm). How can i fix this?
A common problem is the tension pulley bearing going bad, it makes a high pitched screeching noise.
