-   -   EGR Valve troubles (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/egr-valve-troubles-186/)
gohsthb Oct 10, 2005 03:22 PM
My egr valve is apparently sticking again. I thought that I read
somewhere on here that there is a way to clean it out and make it work
again. I have a '92 SOHC SL
Thanks
Crispy983 Oct 10, 2005 07:00 PM
I got an engine code claiming mulitple random misfires (the first time, then cleared the code) then i got cyliner 4 misfire, and egr malfunction. I took the airfilter off and it ran better so i cleaned it now the car works great. Previously it was bogging down when i hit the gas, lost all power and acceleration.
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
stevestar99 Oct 12, 2005 04:08 AM
Pull the two bolts, look down the air by-pass ports, scrape out the carbon, check the plunger for a good seal and free movement. Your done.
