Speaker time
Old 10-14-2013, 02:16 PM
Mac_55's Avatar
Default Speaker time
Just bought a 97 sl1 for savin gas , real nice car,
front passenger speaker was not working and rear passenger speaker was not as loud as the other rear,
used rear pas, speaker to test front, speaker works great and is now my new front,
swapped rear wires speaker to speaker and i seam to not get as much sound out of the one rear pas, speaker plug,
Any one have any suggestions as to maybe its the stock radio, a new one will be going in shortly
Thanks
Old 10-14-2013, 04:38 PM
SAME ohm speakers?
Stop in the new member are and give yourself an introduction. When done open the USER CP top left and add your first name, location, and car into to your "signature".
Thanks
Old 10-14-2013, 06:28 PM
keith's Avatar
I replaced my factory radio with a mild aftermarket, 22 watts per channel and it didn't take long to blow out the factory speakers. I'd recommend that you plan on doing the whole package. You need 6.75" speakers so that limits your choices some.
Old 10-14-2013, 09:34 PM
timmerz's Avatar
Are there ANY really decent 6.75" replacements out there??
Old 10-15-2013, 02:11 PM
keith's Avatar
Quite a few actually, most are 6.5 with an adapter. www.crutchfield.com is a good source of speakers and they provide adapters as needed. I got Polk Audio's from them which were listed as 6.75/6.5 but they only fit with the adapters. They have other brands but they don't seem to carry "cheap" speakers. If your looking to spend less than &60/pair, you'll have to go to Walmart and take your chances.
I mounted mine using a dynamax sound absorbing mat around the edges. I dampens vibrations from the speakers so they don't transfer them to the door frame and window ledge. That would "color" the sound.
mykall
Saturn Aura
03-15-2016 09:44 AM
wmk0002
07-29-2015 11:42 AM
shordinges
06-15-2009 02:21 PM
Plasticmobile
04-11-2007 02:04 AM
Forgiven
Audio/Visual Electronics
02-01-2007 02:12 AM
Quick Reply: Speaker time
