-   -   coolant light (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/coolant-light-3470/)
volfan945 Jul 8, 2009 11:04 PM
coolant light
can someone tell me how to get the low coolant light to go off? (coolant is full) ..ps derf..your the man:D
budsjlm Jul 8, 2009 11:11 PM
make sure you conection for the sensor is hooked up (bottom side of the resivour)
derf Jul 9, 2009 01:39 AM
Also check wiring.....if all is well, sensor inside reservoir tank is either gummed up or has gone bad. Sometimes you can free it up with a reservoir cleaning (empty/remove/soak/retry); sometimes you need to replace the sensor. Not uncommon.
